RCU Forums - View Single Post - Blade CP and Eclipse 7 settings
Old 11-16-2006 | 08:57 PM
will1563
Default RE: Blade CP and Eclipse 7 settings
Altrex
I can share the settings that I used to set the blade cp up with an Eclipse 7. No guarantee that they will work on yours though.
The settings worked quite well, no adjustments were made to the helicopter linkages.
Radio settings:
Heli
PPM
Negative shift
Swash 120
Reverse channels 2 and 6
EPA setting on channel 3 L/U set at 125% ( so unit will arm). All other EPA's at 100%
Exponential at -10% Channel 1, 2 and 4
Swash setting CH#1 @ +70, Ch#2 @ +70, Ch#6 @ +70
Throttle curve (normal) 0, 25, 50, 70, 90
Pitch curve (Normal) 50, 55, 60, 65, 70
RVMX @ 0
These setting are far from tweaked, they were just a test to see how the heli responded(it flew quite well with the above settings). There was such an improvement that I went ahead and programmed it on my Futaba 9C, what a treat to fly now.
Hope the setting help you out, you just need to keep tinkering with the throttle and pitch curves until you get everthing going smooth.
