RE: Beginner Build, Sig Somethin Extra
I have built two of these and still want to build another. This is a very fun plane to fly/build it is hard not to build correctly if you follow the directions and think things through. I would recomend a fuel hatch on this and all planes that one can be built for because at some point you will need to get to your fuel tank. This planes like power too, you can use anything from a good 46 to a 90 on the nose and it will fly good. If you are a beginner use the 46 if you can handle more use the Tower 75.
