ORIGINAL: TomMoorehouse
I'm pretty sure I'll use the trinity motor as I can't find a russian .09 marine. Or maybe the AP Engines Hornet .09 R/C but i'm kinda leaning towards the pull start for a fun boat.
If you went away from the pull start, that OS .18CVRM without a pull start is only 15 dollars more than the trinity with one...probably a bigger motor than you wanted to use... Not sure if you are trying for "cheap to build", "speed" or "small".
Also, your picture did not come through in your last post.
http://www.firefighterboats.com/babbyff.gif comes up as a dead link to me.
Sean
