RCU Forums - View Single Post - 73" yak evolution 26gt
Old 11-20-2006, 02:51 PM
  #83
Macommy
Default RE: 73" yak evolution 26gt
Reeza,
Has Quique tried any other props on the EVO and has he tried a tuned pipe. If not will he consider doing this and doing an update on his findings. This plane and motor could be perfect for me if I can get a bit more power. Unlike Quique, I need that power or the plane will not last long.
John
ORIGINAL: Rezagh
The video was made to help you guys make the right decision based on your expectations. It wasn't meant to sell you the engine! The shots were taken such you can see the pull out of the hovers and overall performance of the engine without hiding anything. As long as you can keep the RTF weight under 12 lbs and it's not a 40cc or up engine, you guys can put any engine you want. For higher altitude, I don't even recommend a gas engine. I think glow is the way to go.
Reza
Macommy is offline
