RE: any problem with this setup?
They actually recommend the 40 amp Jeti. At Hobby Lobby the 2826/12 is packaged with the Jeti 40 amp in a combo deal. I think you will be fine. If you have a watt meter you may want to hook it up and see how much throttle you can get before you start pushing that 40 amp mark. With the right prop combo, you should be good to go. Maybe an 11x6 or 12x6 prop.
