RCU Forums - View Single Post - ESC problems?
Old 11-27-2006 | 10:21 AM
jdetray's Avatar
jdetray
Default RE: ESC problems?
Hooking up an uncharged battery would not damage the ESC. Is your battery now charging properly?
Did you set the throttle reversing switch to reverse on your transmitter as described in Step 5 of the ESC instructions? You must do this if you have a Futaba transmitter.
- Jeff
