ORIGINAL: tmanbu
did you try putting your finger over the exhaust out-let while you crankt the motor to see if you can see any fuel moving through the lines. There could be a block in the lines some where.
i do it all the time there shouldnt be a block anywhere tho since ive changed everything from the tank to the carb
