RCU Forums - View Single Post - Converting Glow to Ignition???
Old 11-28-2006 | 02:42 PM
  #34
aero nut
Default RE: Converting Glow to Ignition???
Have any of you guys ever tried the GAS/GLOW mix on your glow engines??? a friend of mine has tried it on an O.S. 40 using 33% methanol, 66% 91 octane gasoline after mixing this combination he then made a 10% amzoil oil fuel (90% fuel mixture with 10% amzoil) and we were impressed with the the way the little engine runs, so I know it could work on bigger glow engines like the supertigre series or the mokis, I know that morgan fuels makes a special blend of glow fuel for the supertigres that only contains about 5 to 6 percent oil, so that tells me that 10% or even less oil should be enough for the GAS/GLOW fuel mix to be run on glow engines, also we need to take into consideration that gasoline has some lubricity by itself compared to methanol that has none (dry).
So give it a thought, this fuel mix is being used on weedwacker conversion engines with great results at a much lower oil concentration (3%) because they have needle bearings and can run with less oil.
