ORIGINAL: Fastsky
First off there is a major probem on the Super Tigers that no one has mentioed. The carb barrel has a rough finish that will grab and lock the throttle in one position. This happens with out warning and can happen before the engine has even run 5 tanks of fuel through it. This problem is apparent in the smaller ST engines as well. Not to mention what a pain they are to try to get a relaible run out of them.
How many times have you experienced this problem with the ST carb barrel? Do you have any pictures or correspondence with ST about this problem? It is interesting that you have posted this complaint twice in the last 2 days and nobody else has talked about any similar carb problems with the ST engines.
Jeff
