RCU Forums - View Single Post - question.
Thread: question.
Old 11-29-2006 | 03:50 PM
Taxidriver
Default RE: question.
It depends on the type of seal you use and how tight you you want the seal on your shaft, if you plan of packing the seal as well, how fast your shaft is coing to spin, how true your shaft runs and if you generating positive (piston tank), negative (RCABS) pressure inside your WTC. In practice I lose RC signal long before my sub leaks.
