RE: DA50 - Hard to Start, Idle Unreliable
The idle will get better as the engine breaks in. Mine was like yours at first. Now after 15+ gallons it purrs at 1600rpm. It got loads better around 5 gallons. You also may be a bit too lean on the low end. On a DA50, you want to hear it burbling just a tiny bit up to the transition.
