RE: Slow stick interference
If all else fails get a CC Berg microstamp receiver. I've had problems with several receivers/Planes but after using the Berg no more problems. The ant. wire is longer though and I just let it dangle from the rear of the plane. I couldn't even get the receiver to glitch when I turned on another Transmitter on the same frequency. One drawback, you can't use the buddy trainer system with it.
Vultch
