RCU Forums - View Single Post - beginner mojo setup
Old 12-04-2006 | 02:40 AM
XJet
Banned
Default RE: beginner mojo setup
If you've already got some spare standard servos -- then use them. Avoid the temptation to use mini-servos for the flying surfaces -- you're going to have some prangs and mini-servos strip much easier than standards.
If you want to buy some new servos and like Futaba then lots of folks like the S3010 -- it's plenty strong (90oz/in on 6V) and also pretty fast. What you really ought to do (if you haven't already) is use a 5-cell pack for your receiver. It makes a lot of difference to the power and speed of your servos. I like the 1050-1400mAH 2/3A packs that you can get from a variety of sources. They're light (just over 4oz) and provide lots of flight time. They're also heavy-duty enough to use with digital servos on bigger planes if you decide to do this later.
As for receivers, a standard-sized receiver will be fine if that's what you've got -- otherwise you can save an ounce or so by going to a smaller (but FULL RANGE) unit such as an Electron 6 or LightFlightRC D6 which (at $27.95 plus crystal) are hard to beat -- value-wise.
Any of the engines you listed will be fine -- but if you're thinking 4-stroke I'd go for the 82 over the 72, there's not a great price difference but the 82 is a much stronger and more reliable motor than the 72. However, I'm in favour of learning 3D with a 2-stroke because they cost less so you won't be so worried about dorking it and therefore be a little more willing to fly "on the edge" :-)
But, when it comes to flying profiles, my motto is: "Use what you got and fly what you use -- until your thumbs start bleeding" :-)
