RE: list problems to look out for with the Thundercat 31
The strut is set too shallow so drop it down when using the stock prop. It wouldn't hurt to replace the rudder linkage with some 4-40 threaded rod.
The above will get you on the water but then later on, go to the TC 31 thread to see what else you can do to it.
