RE: 85 ft Harbor Tug/Angels Gate
I no longer have anything inside the tug. I stripped it all down when I knew it wouldn't be going to the pond any more. What I did have was a hectoperm 3:1 motor, vantec ret-44 esc, 12 volt 7 mah battery, bec Futabe Rx. With the hectoperm motor this tug would pull or push anthing. It was really a terror on the water it had so much power. I am using it now on a 45 inch hull that I am making into a fireboat. The hull was an old Dynamic Hobby hull if you remember them? They were on Long Island when they were in business some years back. All I did was install a floor on the inside and mount everything to that. It is all pretty straight forward sorry I no longer have everything installed to show you.
Tug
