LOW,MID,HIGH TIMING
Good morning to you all
My problem is I have an ALIGN 25 amp esc that I want to use with a Himax 2025-4200 gearded motor The manual states use low timing if the motor is 2 pole mid timing if it is 6 or more poles.Well I have no clue how many poles this Himax has.I tried mid timing and it seems to run fine on a 2100 mah 2s10c lipo pack but on a 1100 mah ni-mh when it does run the RPM will hunt at WOT,most of the time with the 1100 ni-mh the motor will just sit and chatter and not run at all.I know someone has the answers you guys always do.
