RE: battery out
What current are you charging at? Did it always do that or did it just start? Have you tried charging a different battery/charger? You're definitely not charging it all the way so something is wrong somewhere. I wouldn't use the battery until you get the problem solved since you're using up its useful battery life. LiPos are not the cheapest things in the world.
