RCU Forums - View Single Post - I Feel Ripped Off
Old 12-12-2006 | 05:44 PM
Robrow's Avatar
Robrow
Default RE: I Feel Ripped Off
Jesus, there are 2 trophies to be won, one for best fuel efficiency and the other for best thrust/weight ratio. Engines have to be run at the same rpm for 2 mins minimum, so once the engine is settled at the selected rpm and the operator is happy the run is timed with measurements of fuel used and thrust taken.
If a particular engine has it's max efficiency point less than max thrust then 2 runs would be required at the appropriate rpm points.
Hope thats clearer.
Rob.
