KK
Hi,
Built per plans easy to build.
standard servos on all . yes I used the FMA auto pilot on the cyclic only.
OS 70 Surpass 4 Stroke
4 517 Jr servos
1400ma battery
JR R600 reciever
FMA Co-pilot
the only thing i messed up on was the vertical stab when you get the plans you have to build the fuse first and the vertical stab did not fit so i cut it to fit. but when I started building the head assy they told me to bend the screws for the rudder to make it line up.
I guess to set it back away from the blades but it worked fine.
still working on landings try to auto it in it comes in a little hard but im sure thats my ignorance.
Eddy
