RCU Forums - View Single Post - Pull \ Pull Elevator control or direct servo hookup?
Old 12-21-2006 | 12:05 AM
lwmatch
Default Pull \ Pull Elevator control or direct servo hookup?
Help!!!
I have a Sig Rascal 110 with a Supertigre 3250 with larger tires for Grassfarm Field, I am slightly nose heavy. I can add 6 oz. of weight to rear stab. but would rather relocate my elevator servo if this makes more sense. Right now my elevator is using the pull-pull cables with the servo [hi-torque] mounted about 2 feet from the elevator. This plane has a cutout in the aft area for direct servo to elevator hookup, but with the throw range and size of elevator, I don't know if this is as safe or as strong as the 4-40 pull cables. Please pass on your thoughts or opinions of these choices.
