RE: Ultra RC 87" Yak Build and Fly
I agree there are alot pf people who use the down elevator mix to correct down lines. My hunt was on due to issues with too much trim on the ailerons. Further investigation revealed twisted ailerons as reported in another post (thanks for the reminder) This is not uncommon and should have been on my check first list. I will probably end up with some down mix on the elevator but it flew so well inverted and with no up elevator trim the downlines were perfect. Just trying to get rid of as much trim as possible before starting to use mixes. This is possibly the best Yak I have flown it flys very light and response is immediate. I would definately recommend this plane to others ( and have already). Every plane has some mix in one way or another including my pattern planes.
