RCU Forums - View Single Post - COMBAT WING SHAPE
Old 12-24-2006 | 12:28 AM
Reverse_Sensing
Default RE: COMBAT WING SHAPE
As Kirk mentioned, the sweep of a wing does dramatically change both the CG and the aerodynamics of the specific design of an aircraft. The forward swept wing usually suffers more aerodynamically speaking due to increases of drag and compensation for aft CG's. There are a couple different aerodynamic factors that contribute to the decrease in performance which may cause a slight difference for an aircraft.
First and most obviously, there is more LE surface perpendicular to relative wind with a forward swept wing resulting in more parasite drag, and therefore a decrease in performance. Second, the forward swept wing even though more efficient at producing lift while flying at lower speeds, suffers once again to a different type of drag called induced drag. Induced drag is a direct bi-product of lift. The more lift a wing produces, the more drag it will also produce. This is one of the main reasons why trainers with high lift producing wings fly slower and require much more power to maintain a certain speed when compared to a symmetrical airfoil. Their highly unsymmetrical wing produces large amounts of lift therefore higher amounts of drag. This is why you see higher performance aircraft with thin symmetrical swept back wing which leads me to my third and final aerodynamic point. Each specific wing produces lift on one focused portions of the wing called the center of pressure. The center of pressure is usually aft of the center of gravity on most aircraft (25% Mean Aerodynamic Chord or approximately 25% of the way back from the LE). When the wing travels through the air at a faster speed, the center of pressure will begin to shift rearward resulting in less pitch stability and eventually less yaw then less roll stability at higher speeds. The aft swept wing allows for this shift and compensates for the center of pressure movement making high speed aerodynamics possible. However as Kirk mentioned above, these factors will not take affect until much higher speeds (Mach range).
To sum it up however, wing shape will probably not affect your combat bird as much as you think when compared to other issues like center of gravity and aircraft weight. Each aircraft has a specific envelope or range where the CG can exist safely. Paying very close attention to these will prove to be much more valuable when flying. Overall, I prefer a solid lift producing and stable wing. Forward swept wings or rectangular types will generally produce these favorable qualities. It requires less aerodynamic input, therefore resulting in less drag making the aircraft faster, and overall ease of flying. Aft swept wings will be more difficult to fly at slower speeds and probably less of an advantage throughout all aspects of RC flying.
