ORIGINAL: rgrove
ORIGINAL: roltech
ORIGINAL: Stickbuilder
One other thing, When you had the pump apart, did you lube the diaphragm? Sometimes they dry out, and It could just possibly be that you are not getting sufficient movement to pump at low speed. a very light film of petroleum jelly might do the trick. You might want to gently rub it into the material.
I now have taken the motor to the LHS and parts are on order, There seem to know what is wrong, only problem parst are hard to get. I'll let you know what comes out of this.
roltech
One other question - I couldnt tell from the pictures. Did you have the fuel to the carb going through the easy-filler? If so, those are notorious for developing very small air leaks, causing the symptoms you describe. I have had a friend of mine chase that thing for days on a 4-stroke. Replaced the valve and all was right with the world.
Dunno; just a thought.
Thanks for getting back! The motor is still at the LHS, last thing they told me that they had a part for it and they would try to install it and will let me know, (very slow process)
so if ever they get it going I will post the results.
roltech
