RE: How does the flywheel fit onto an engine like the .12CVR
looking at that set up its not familiar to me my sc has the tapered collet.you may not be able to get a flywheel to fit that engine.the fly wheel needs to have the tapered collet wether you can get a different one for your engine i dont know.maybe you can get one made to fit that will work but every one ive seen has the tapered collet, sorry i cant help more.what flywheel have you got? will the collet fit onto the shaft if you remove the spacer(drive hub).
