Engine test stand
The throttle-stop mechanism was a 3/4" bolt that I cut off the hex head and threads, drilled and tapped the bottom to mount to the base plate, and drilled and tapped the top to accept the wing bolt. A "pass through hole" is drilled for the pushrod where the wing bolt will tighten onto the pushrod to hold it at any position.
