ORIGINAL: 9757
I have no intentions to adjust valves or set timing!
9757,
You are correct, a Saito will need a valve adjustment once a year. Fortunately it only takes 5 minutes. Regarding setting the timing, I'm not sure which engine you are refering to. A Saito does not have a way to set the timing. The cam is driven by gears.
Phillip
