RE: Motor on Glider Shutting off Prematurely
Sounds like a battery/charging issue.
What charger are you using, and did you do a 16 hr. forming charge at 380MAh?? If you have a voltmeter try checking the battery voltage under load, better yet get a Watt meter so that you will know how many amp you are drawing.
Pete
