RE: Nitro hammer problems! Help!
Wehn I got my son's in it had a cracked fuel tank right where the screw holds to the cross stringer. The fuel was leaking everywhere. I basically couldn't get it running. I changed tanks and now I can get it running , but not with the settings that the book says. I has th HS needle at 3.5 out and the LS needle at 4. It seems as if at 2-2.5 on the HS needle the fuel doesn't flow into the carb.
