RCU Forums - View Single Post - thunder tiger trainer 40
Old 01-03-2007 | 01:42 PM
bigedmustafa's Avatar
bigedmustafa
Default RE: thunder tiger trainer 40
While mostly known for their outstanding engines and helicopters, Thunder Tiger also makes very high quality airplane ARFs. Thunder Tiger ARFs are very well constructed, and generally come with thorough, clear instruction manuals.
Finding spare parts for Thunder Tiger products used to be a bit of a problem at times. Now that http://www.thundertiger4u.com is available, you can find replacement parts for most any ARF or engine that Thunder Tiger manufactures. At the front of the manual for most any ARF is a parts inventory that is seperated into groups of items, and each group has its own parts number. If you need a replacement item, you simply order that particular group number.
For example, if you're flying your Thunder Tiger Tiger Stick .40 ARF and you accidentally smash your wing to pieces, all you have to do is find your manual for the plane. The wing set is listed in the manual as #AS0081 and includes left wing w/ aileron, right wing w/ aileron, wing center tape, aileron servo tray, plastic wing plate, plywood wing joiners, and torque rod horns. If you go to http://www.thundertiger4u.com and enter the part number AS0081 into the search engine, up pops the wing kit for the Tiger Stick and you can order it on the spot.
Thunder Tiger is known the world over for making exceptionally high-quality products. Now that http://www.thundertiger4u.com is readily available to supply these products as well as the spare parts needed to support them, hobbyists no longer have to worry about keeping their Thunder Tiger products running for a long, long time.
