ORIGINAL: MasherBasher
i have all the drive chain bits sorted. including the final gears. i have all the nessesary bit on order. i have just been looking around the net though and i stumble upon the hyper 12 which seems to be extreemly cheap for what it is. it comes with the sg shaft and the slide carb but would this be powerful enough to move an mt2 with mashers?
Do you have alloy differential housings? Make sure you shim the differentials properly. Do you have all the heavy duty CVD, heavy-duty drive cups and center dog bones like on the SS? Do you have the big block conversion kit or are you going to make that? Buy the time you buy the conversion kit and the engine might be better just getting a TZ.
