Old 01-04-2007, 02:38 AM
RickShaw739
Default RE: Fluttering Servo
ORIGINAL: HuskerBoy
I've had this happen after a full charge on the Rx pack. Did it still happen doing a range check OUTSIDE ? Often checking setups in the shop can overload the signal and cause one or more servo to flutter if the Tx is too close.
I'll give the outside range check tomorrow and see. The battery I just looked at it and it's at 4.9 ...it's also a new pack.
