ORIGINAL: MasherBasher
thats sounds like crappy clutch springs then. if it was slipping so much then they mustve been crap springs.
If you go to the Savage forum you will see this is a common problem with the stock shoes. Has nothing to do with the springs as the springs only retract the shoes. I put the alloy shoes in with the same springs and did not have a problem! The alloy shoes hook up great. Like I said go to the Savage forum and look around. [8D]
