RCU Forums - View Single Post - #2 - Tech Question: ARF Build, 3D Plane
Old 01-07-2007 | 09:21 AM
bbellfly
Default RE: #2 - Tech Question: ARF Build, 3D Plane
Thanks guys....
I looked at all the ideas given. The solution I have choosen. I lightly sanded inside the fuselage opening for the harizontal stab. On the high side I sanded the bottom. On the low side, I sanded on the top. Just enough to alow aliginment. When epoxing in place, I place some thin wedges of balsa. Don't get the impression there was alot of movement, it was only enough to allow aligiment. The tips of tooth picks would barely fit. I used enough epoxy to completely saturate all peices, then wiped down the amount that oosed out.
Thanks again for all your thouhgts.
bbell
