ORIGINAL: Richard L.
ORIGINAL: impalaman63
14x8= 112 and a 16x7 = 112 WHAT DO YOU THINK?
Sorry, the product of the diameter and the pitch doesn't mean anything. It's just how we express diameter and pitch in writing (similar to a 2x4 block of wood). Other places of the world write 14-8 or 16-7, and subtracting 8 from 14 or 7 from 16 doesn't give anything.
Yes, 14x8 is faster. An engine that spins a 14x8 prop won't be able to spin a 16x7 prop (too big).
It's called LOAD FACTOR. The load factor is a way to measure the total load on the engine by using some simple arithmatic and multiplication.
The equation goes like this:
(Dx2) + Pitch = LOAD FACTOR
D means DIAMETER.
So, for a 14x8 prop you would figure it out like this:
(14X2) + 8 = Load Factor
Which comes out too:
28 + 8 = 36
Now a 16x7 blade would figure out like this:
(16x2) + 7 = Load Factor
32 + 7 = 39
So, your Load Factor on the 14x7 is 36
Load Factor on the 16x7 is 39
The higher Load Factor will load the engine more and you'll loose RPM.
BUT, lower RPM doesn't necessarily mean less thrust. You can actually get more thrust from a larger blade with less pitch. Even though it is turning less RPM--it will produce more thrust. Look at thrust as a hole shot. More thrust--more hole shot. You won't get the same top end speed out of a thrust prop, but it will take off quick.
Thats why 3D pilots use big props with only a little pitch. They don't want a fast airplane. They want it to accelerate out of a hover--RIGHT NOW!! And thats what a big prop will do for you. It's like taking off in first gear with a top speed of 15MPH. It's not fast, but it gets to top speed REAL QUICK.
Now look at a high speed racer:
Little prop with lots of pitch. Very high RPM and extremely fast because the small diameter allows the engine to wind up very high. It takes a bit for the engine to wind up and get to full RPM because the pitch is so great. That adds load too.
The problewm with a high speed prop is it takes a while to get wound up. No more hole shot. It's like taking off in overdrive gear with a top speed of 100MPH. It takes a bit to get there, but it's fast.
