RE: Perry Pump
Thanks guys. I think I found a way to fit the 8 0z tank in, so I can just use one single tank. My concern now is the pump... as far as it possibly delivering too much fuel to the engine. I have attached a "very" basic diagram showing where components are to be located in relation to each other. The engine is mounted on a pod at the rear of the plan, and the pump will have to draw fuel approx 22-1/2" to the rear of the plane, about 8" up the middle of the fin, then about 5" or 6" forward toward the engine. Will the pump still be delivering too much fuel for the OS .46 AX in this configuration?
