RCU Forums - View Single Post - Volt,Amp,Watt,RPM,Windings......
Old 02-01-2003, 09:00 PM
hdebruin
Default Volt,Amp,Watt,RPM,Windings......
Originally posted by Steve Lewin
It won't tell you much about "windings" because it's only car guys that talk about those all day long.
Steve
<comes running back from EZone>
Dang ! You is a celebrity ;-)
Yes, I don't want to start winding myself, but doesn't the nr of windings in a stock motor say anything about its torque, rpm, amps, volts whatever to be able to match it to a certain airplane ? Like with an IC engine the bore/stroke ratio says something about an engines performance, even if I don't intend to build one myself.
Anyway, lots to learn.
Hans
