RCU Forums - View Single Post - Volt,Amp,Watt,RPM,Windings......
Old 02-02-2003, 10:11 AM
Steve Lewin
Default Volt,Amp,Watt,RPM,Windings......
Simplified view of windings (or turns).
If everything else is the same, i.e. motor size, # of poles, brushed/brushless, strength of magnets etc and the voltage you're using :
More turns = lower current, lower revs, better torque
Less turns = higher current, higher revs, low torque
So typically for the cheap Speedxxx/RC car-type motors:
higher turn motors will turn bigger prop without taking too much current and without a gearbox
Lower turn motors can only turn a small prop direct drive so are usually used with a gearbox.
Steve
