Old 01-10-2007, 02:05 PM
vicman
My Feedback: (10)
vicman's Avatar
Default RE: Burp tank-what is it?
The use on the b-less tank is to make sure that there are no bubbles in the tank. Using the Jett pump jaka mentioned you would suck the bladder dry and then refil the bladder with fuel. Both methods keep air out of the tank. With the pump you will get more fuel into the tank since you are squeezing the air in the tank out thru the exaust inlet line thus the tank is almost pressurized.
Bob27 can comment more in detail or you can go to the Jett site.
