RCU Forums - View Single Post - Noob here
Thread: Noob here
Old 01-10-2007 | 04:26 PM
wst50
Default RE: Noob here
ABS is a plastic. It is bought in tubes (when you want to drift) as it has low friction, making it good for sliding about.
Nitros don't reverse unless they have a gearbox with reverse in it. It's common to not be able to reverse in stock nitro RTRs. As for the battery problem, try getting another pack (the same physical size), but with a higher mAh rating to make it last longer.
