RE: Why is it so hard to make servo extensions?
One thing you can do is cut the servo wire and splice in your extension wire to the desired length. I do this on all my planes and feel it is more reliable than trusting extension plugs. (they can sometimes vibrate loose or not make good contact.) I solder the wires and use heat shrink tubing which makes a permanent and failproof connection.
