I use normal fuel line for everything. You don't need anything inside the tank for the filler. It can just be a straight line in. you want your exhaust line to come in and bend up to the top of the tank to allow you to fill it all the way, this also prevents pumping in so many airbubbles and foaming of your fuel while the engine is running. I can take a pic of the Sullivan tank instructions if you need.
