ORIGINAL: m3pgi
wow
those mini sl's look fun!
what type of ca do u guys recommend. can i use gorrila glue
Yes, there are pretty fun and basically unbreakable (Almost).
Ca works but you must use the foam safe type and the accelerator to dry it. It's not cheap though and makes for a brittle repair.
I like using hot glue to repair EPP foam. It's cheap, but you can't let the glue get to hot if you use the high temps gun/glue. it can melt the foam from the heat. If the glue gun has been sitting for awhile I will squeeze out the first part that is real hot to get to the cooler stuff.
Gorilla Glue works fine also, but the repair does show up some as the glue is a amber color, and it expands slightly. Dries kinda slow unless you apply a little water on one side of the foam, but the repair is very durable.
