RCU Forums - View Single Post - Offcial xxx-t thread
Old 01-12-2007, 09:56 PM
  #390
Motoman8504
Default RE: Offcial xxx-t thread
That looks like it will work great. Nice job. One suggestion though, you might want to put something soft on the bottom of the strap just to help cushion the battery.Plus, it would prevent the battery from getting scratched up from rubbing on the strap. Oh, and by the way you're prbably going to have to cut a small notch in one of the battery sidewalls for the battery wires. A buddy of mine has the 3S 4000Mah Maxamps battery and the wires just won't bend enough to run parallel with the sidewalls on the inside. Just thought I'd give you the heads up. Let us know how it works out.
