RE: New Piedmont Focus 90/110
Electric power systems can vary considerably, but I'll take a shot at an affordable one (E-Flite outrunner) and a more expensive one (Hacker Inrunner) if somebody would post the wing area. As it is I see the weight is 7 lbs 10oz with the Y.S. 1.10. According to the specs at Central Hobbies that's approximately a 26 oz motor. The wing area given is 66". I'm going to use my air density here at 800' MSL and plug everything into Motocalc. I should get a couple pretty good answers, but I won't guarantee they will be the very best answer for this plane. That usually takes some time and it also is dependant on the plots preference.
So, with that in mind, what's the wing area?
Cheers,
Wiz
