RCU Forums - View Single Post - Diff lock
Thread: Diff lock
Old 01-17-2007 | 07:01 AM
The Real Dogman's Avatar
The Real Dogman
Default RE: Diff lock
if you have an electric stove you will not have to worry about running out of butane, be sure to use a good quality driver..if that still does not work then get a [link=http://www.aldn.com/grabit/]Micro Grabit[/link] to remove the screws. If that still does not work then you will have to drill the heads of the screws off and trash the diff housing.
Hope this helps..
