Thread: Saito Carb
Old 01-17-2007, 10:35 PM
khodges
Default RE: Saito Carb
Yes. All you have to do is remove the two screws that hold the carb body to the rear of the engine. Rotate the carb on the intake pipe and replace the screws and snug them down. You might have to swing the intake pipe out a little to allow the carb to turn. The intake pipe is an interference fit in the intake port, and has a small o-ring to seal it, same where it fits into the carb body.
