RE: After run oil in OS engine carb.
Actually OS has no such injunction against after run oil down the throat
of the carb. What is meant in the manual is they do not want you
injecting oil into the fuel inlet. Down the throat is fine.
This info came from Bax from Hobby Services. The confusion
stems from the translation of the OS engine manuals.
Also 8-9 drops is not really enough to do much. I use about a teaspoon
if its going to be more than a couple of days before I run it again.
Mike Hammer
