RE: HELP!!
Ok I got ya, if this is the very first time ever running the car I would check and make sure the crystals in the transmitter and reciever have the same numbers on them, if they don't you run to your LHS and see if they have an AM crystal set. If the crystals are the same then that means you have a bad transmitter. The redcat radio sets are supposed to have a 30 day warrenty. If the case is that you have a bad radio set we will warranty it for you or i'm sure clermontmotorsports will too, all you have to do is send the old radio and we will gladly send you a brand new radio free of charge.
You can get those parts from either allaboutfunhobbies or Clermontmotorsports.
