Caad5, I'm preparing car almost like yours, I took your picture as reference for my installation, I have problem with servos for hydraulic breaks, I install them exactly like your but when I made test both are working well but with opposite direction i.e the front break work the rear released, the front break work the rear break released , I'm using Y cable to connect both break servos , would you please tell me how you manage to let both working
ORIGINAL: caad5
Fitted with the following FG Components:
Alloy Front Upper Wishbones
Alloy Front Lower Wishbones
Alloy Front Uprights
Alloy Front Shock Tower
Alloy Servo Saver
Alloy Gear Plate
Alloy Gear Carrier
Alloy Engine Mounts
Alloy Diff Mounts
Alloy Rear Upper Wishbones
Alloy Rear Lower Wishbones
Alloy Rear Lengthening Set
Alloy Rear Uprights
Alloy Rear Shock Tower
Alloy Rear Spring Deflection Limitation Set
Alloy Ball Joints
Viscous Diff with extra 6 Fins - 12 Fins Total
Ball Drives
Wheelie Bar
MT Front Bumper Bar with Lights
MT Shell - Fully Painted
MT Roll Bar with Lights
Zenoah 26cc with Porting, Lightened Piston,Sealed Crank and Heat Shield approx 6+HP
Steel Pinion
Chrome Tuned Pipe
K&N Filter Set and Alloy Adaptor Plate
Front Magura Hydraulic Brakes
Rear Magura Hydraulic Brakes
Tank Ventilation Kit
Tank Foam
Special Fuel Filter (stops formation of bubbles)
