RCU Forums - View Single Post - HS-55 Servo Upgrade
Old 01-24-2007 | 07:58 PM
bryon261
Default RE: HS-55 Servo Upgrade
do they improve flight control that much i can hover my axe for about 4 seconds before it wonders off never in the same direction. one thing i did to improve flight control was to add 1/16" collars to the flybar. start with them postioned up to the flybar carrier and moved one outwards towards the paddle until balance was perfect or close enough. my heli fly so much better , more control. i'm going to try blade cp paddles next, i just hope it does not dampen the response too much, i'm use to quick responses . if you don't have a quick reactions to movement how would you be able to hold a hover. i'm constantly making corrections.. could this be a servo issue?
